Aller au contenu principal
Anglais
Français
Traduction de l’étape 1
Étape 1
If you purchased an optical drive with the PCB board and bracket included, skip the remaining steps and begin reassembly. Remove the three 6.2 mm Phillips screws from the metal bracket.
Remove the PCB
  • If you purchased an optical drive with the PCB board and bracket included, skip the remaining steps and begin reassembly.
  • Remove the three 6.2 mm Phillips screws from the metal bracket.
Si vous avez acheté un lecteur optique avec le PCB et le support inclus, ignorez les étapes suivantes et commencez le remontage.
Retirez les trois vis cruciformes de 6,2 mm du support métallique.
