Aller au contenu principal
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 7 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 2
Étape 2
Use a Phillips screwdriver to remove the 6.5 mm screw securing the hard drive bracket to the enclosure. Use a Phillips screwdriver to remove the 6.5 mm screw securing the hard drive bracket to the enclosure.
Remove the hard drive bracket screw
  • Use a Phillips screwdriver to remove the 6.5 mm screw securing the hard drive bracket to the enclosure.
Retirez la vis cruciforme de 6,5 mm fixant le support du disque dur au boîtier.
[title] Remove the hard drive bracket screw
-[* red] Remove the 6.5 mm Phillips screw securing the hard drive bracket to the enclosure.
+[* red] Use a Phillips screwdriver to remove the 6.5 mm screw securing the hard drive bracket to the enclosure.
