Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 5 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 1
Étape 1
Peel up the six cable loops securing the antenna cables to the upper case. In some models there are seven cable loops. Gently pull the cable loops slightly out of the channel cut into the upper case one at a time.
  • Peel up the six cable loops securing the antenna cables to the upper case.
  • In some models there are seven cable loops.
  • Gently pull the cable loops slightly out of the channel cut into the upper case one at a time.
  • Use your spudger to open up the plastic loops as you de-route the antenna cables through them.
  • Repeat this for each retaining loop until the antenna cables are free from the upper case.
Insérez ici votre traduction
