Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Anglais
Français
Traduction de l’étape 1
Étape 1
Begin by disconnecting your battery, pulling off the negative (-) ground cable.
  • Begin by disconnecting your battery, pulling off the negative (-) ground cable.
  • This is required for this process! There is a constant 12v supply of power to your car's clock, even when the key is off. If you attempt to pull the cluster out with the battery connected you will burn up part of your cluster's circuit board, or worse yet hurt yourself.
Insérez ici votre traduction
