Aller au contenu principal
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 4 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 4
Étape 4
Remove seven black 3mm Phillips #00 screws. The top right corner screw is underneath a yellow ribbon. Lift the ribbon up without disconnecting it and unscrew the screw.
  • Remove seven black 3mm Phillips #00 screws.
  • The top right corner screw is underneath a yellow ribbon. Lift the ribbon up without disconnecting it and unscrew the screw.
Retirez les sept vis suivantes:
Vis Phillips n ° 00 M3,0 x 3,0 mm (noires).
La vis du coin supérieur droit est sous un ruban jaune. Soulevez le ruban sans le déconnecter et dévissez la vis.
-[* black] Remove the following seven screws:
- [* red] M3.0 x 3.0 mm #00 phillips screws (black).
+[* red] Remove seven black 3mm Phillips #00 screws.
[* icon_note] The top right corner screw is underneath a yellow ribbon. Lift the ribbon up without disconnecting it and unscrew the screw.
