Aller au contenu principal
Anglais
Français
Traduction de l’étape 13
Étape 13
This brass gear is the item we are interested in. It is attached to a shaft that is responsible for turning the main odometer gear. This grey gear is the main odometer gear that turns the small plastic gears along the top of the odometer numbers. This is the other end of the shaft the brass gear is attached to. It is held in place by a tight fitting brass ring.
  • This brass gear is the item we are interested in. It is attached to a shaft that is responsible for turning the main odometer gear.
  • This grey gear is the main odometer gear that turns the small plastic gears along the top of the odometer numbers.
  • This is the other end of the shaft the brass gear is attached to. It is held in place by a tight fitting brass ring.
Insérez ici votre traduction
