Aller au contenu principal
Fix Your Stuff
Right to Repair
Parts & Tools
Info : Vous modifiez actuellement un prérequis du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 52 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 23
Étape 23
With the adhesive loosened, you can now insert the pick near the right-hand corner. Slide the pick to the left, and stop just short of the Home button. Just like with the left antenna, only slide from the outer edge toward the center. Reversing this direction may damage the antenna. Just like with the left antenna, only slide from the outer edge toward the center. Reversing this direction may damage the antenna.
  • With the adhesive loosened, you can now insert the pick near the right-hand corner. Slide the pick to the left, and stop just short of the Home button.
  • Just like with the left antenna, only slide from the outer edge toward the center. Reversing this direction may damage the antenna.
Comme l'adhésion a été diminuée, vous pouvez maintenant insérer le médiator dans le coin en bas à droite
Comme pour l'antenne du coté gauche, faites glisser le médiator seulement de l'extérieur vers l'intérieur. Faute de quoi vous déteriorerez l'antenne.
[* black] With the adhesive loosened, you can now insert the pick near the right-hand corner. Slide the pick to the left, and stop just short of the Home button.
[* icon_caution] Just like with the left antenna, only slide from the outer edge toward the center. Reversing this direction may damage the antenna.
