Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 2 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 7
Étape 7
The LCD assembly is attached with a concealed ribbon cable, so be gentle when you remove it. The D ring brackets on either side are not attached, only held in mechanically. Once the LCD assembly starts to come out, they will detach.
  • The LCD assembly is attached with a concealed ribbon cable, so be gentle when you remove it.
  • The D ring brackets on either side are not attached, only held in mechanically. Once the LCD assembly starts to come out, they will detach.
  • Pull on the D rings on either side of the camera to start removing the assembly.
  • Once the brackets are cleared from black shell, take them off and set them aside.
  • Continue to remove the screen assembly.
Insérez ici votre traduction
