Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Info : Vous modifiez actuellement un prérequis du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 35 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 1
Étape 1
Be very careful to pry evenly on the digitizer connector, and not on the socket at all. The socket and connector are very delicate and if you damage either, your digitizer won't work. To minimize stress on the socket, try prying under the short edge of the connector, rather than the long edge which is shown in these images.
  • Be very careful to pry evenly on the digitizer connector, and not on the socket at all. The socket and connector are very delicate and if you damage either, your digitizer won't work.
  • To minimize stress on the socket, try prying under the short edge of the connector, rather than the long edge which is shown in these images.
  • Gently pry the digitizer connector up from its socket on the logic board.
Utilisez un outil d'ouverture en plastique pour tirer doucement le connecteur de la vitre tactile hors de sa prise sur la carte mère.
Veillez à faire levier de façon uniforme sur le connecteur et pas du tout sur la prise. La prise et le connecteur sont très fragiles et si vous endommagez un des deux, votre vitre tactile ne fonctionnera pas.
[* black] Use a plastic opening tool to gently pry the digitizer connector up from its socket on the logic board.
icon_caution] Be very careful to pry evenly on the digitizer connector, and not on the socket at all. The socket and connector are very delicate and if you damage either, your digitizer won't work.
[* black] To minimize stress on the socket, try prying under the short edge of the connector, rather than the long edge which is shown in these images.
[* black] Gently pry the digitizer connector up from its socket on the logic board.
