Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 6 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 1
Étape 1
Remove the six 4.0 mm Phillips #00  screws that secure the midframe to the phone.
  • Remove the six 4.0 mm Phillips #00 screws that secure the midframe to the phone.
  • Ensure you retain all six of the 4.0mm screws! These hold the midframe securely and closely to the motherboard. The three small snaps on the back cover that attach to the midframe ensure the NFC antenna and wireless charging coil connectors contact securely with the motherboard, and work reliably.
  • To replace the LCD screen and digitizer, remove the additional four 4.0mm daughterboard cover screws with the same screwdriver. You may have to pierce through clear adhesive material to remove them.
Retirez les six vis cruciformes #00 de 4 mm qui fixent le châssis au téléphone.
Si vous souhaitez remplacer l'écran LCD et la vitre tactile, retirez également les quatre vis de 4 mm du cache de la carte fille, avec le même tournevis.
[* red] Remove the six 4.0 mm Phillips #00 screws that secure the midframe to the phone.
[* icon_caution] Ensure you retain all six of the 4.0mm screws! These hold the midframe securely and closely to the motherboard. The three small snaps on the back cover that attach to the midframe ensure the NFC antenna and wireless charging coil connectors contact securely with the motherboard, and work reliably.
orange] To replace the LCD screen and digitizer, remove the additional four 4.0mm daughterboard cover screws with the same screwdriver. You may have to pierce through clear adhesive material to remove them.
