Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Anglais
Français
Traduction de l’étape 58
Étape 58
On the right side rear, remove this screw, 3/16-32, threaded length 1/2", and the spring at the indicated point. There is nut on the other side, so it will be helpful to use a wrench to hold the nut. The screw on mine doesn't come off the lever. There is a large bushing between the lever and the frame which does not come off, either.
Remove cam follower on small lever
  • On the right side rear, remove this screw, 3/16-32, threaded length 1/2", and the spring at the indicated point. There is nut on the other side, so it will be helpful to use a wrench to hold the nut.
  • The screw on mine doesn't come off the lever. There is a large bushing between the lever and the frame which does not come off, either.
  • Place in bag 10.
Insérez ici votre traduction
