Aller au contenu principal
Anglais
Français
Traduction de l’étape 86
Étape 86
The only thing now preventing the two frames from being separated is this gear. It is fixed to the shaft with a taper pin.
  • The only thing now preventing the two frames from being separated is this gear.
  • It is fixed to the shaft with a taper pin.
  • A taper pin is a pin that tapers from a wide end to a narrow end used to affix parts onto a shaft. The machinist would put the gear on the shaft, drill a hole, then taper the hole by using a tapering reamer. Then the machinist would put the taper pin in, give it a few gentle whacks with a hammer, and grind off any end sticking out too much.
  • Taper pins were better than set screws because a taper pin leaves no possibility for the parts to rotate.
  • They're also a pain to remove after 90 years.
Insérez ici votre traduction
