Aller au contenu principal
Anglais
Français
Traduction de l’étape 96
Étape 96
On the right frame, unscrew this screw. There is a thin nut on the other side of the frame that you should try to hold steady or loosen slightly. If that doesn't work, just slowly turn the screw, since the nut will add lots and lots of friction.
  • On the right frame, unscrew this screw. There is a thin nut on the other side of the frame that you should try to hold steady or loosen slightly. If that doesn't work, just slowly turn the screw, since the nut will add lots and lots of friction.
  • Remove the spring from its post on the frame, and remove the lever.
  • The nut should now slide out.
Insérez ici votre traduction
