Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Anglais
Français
Traduction de l’étape 99
Étape 99
Loosen, but do not remove, this set screw. Slide the ring over a bit. On the right frame, there is a cam ring that is loose. Remove it, if you haven't already. You should now be able to jiggle these levers loose, Remove their springs first. You will probably have to slide the shaft a bit out, also.
  • Loosen, but do not remove, this set screw. Slide the ring over a bit.
  • On the right frame, there is a cam ring that is loose. Remove it, if you haven't already.
  • You should now be able to jiggle these levers loose, Remove their springs first. You will probably have to slide the shaft a bit out, also.
Insérez ici votre traduction
