Aller au contenu principal
Anglais
Français
Traduction de l’étape 2
Étape 2
Remove the foam from the top of the wire connector. Gently remove the plastic connector in the same way as the previous connector of the same type. Lift the connector from the side with the ribbon cable in it.
  • Remove the foam from the top of the wire connector.
  • Gently remove the plastic connector in the same way as the previous connector of the same type.
  • Lift the connector from the side with the ribbon cable in it.
  • Using the spudger, gently push from the right side.
Insérez ici votre traduction
