Aller au contenu principal
Anglais
Français
Traduction de l’étape 3
Étape 3
Remove the two screws holding the valve in place and remove it. It is normally not necessary to open and clean the valve. If you do open it be careful as there are many small parts inside and if reassembled incorrectly coffee will not flow. It is normally not necessary to open and clean the valve. If you do open it be careful as there are many small parts inside and if reassembled incorrectly coffee will not flow.
  • Remove the two screws holding the valve in place and remove it.
  • It is normally not necessary to open and clean the valve. If you do open it be careful as there are many small parts inside and if reassembled incorrectly coffee will not flow.
Insérez ici votre traduction
