Aller au contenu principal
Anglais
Français
Traduction de l’étape 6
Étape 6
Remove the piston gasket and clean any coffee from the channel it sits in. The top strainer gets a bath in some degreasant. A tooth-brush can  penetrate every pore of the strainer. Sometimes can help a tooth-pick. In some cases, a needle will help you too.  Rinse with water. Take a look at the strainer, hold it towards the window or some strong light. you should be able to look through every hole. Well done.
  • Remove the piston gasket and clean any coffee from the channel it sits in.
  • The top strainer gets a bath in some degreasant. A tooth-brush can penetrate every pore of the strainer. Sometimes can help a tooth-pick. In some cases, a needle will help you too. Rinse with water.
  • Take a look at the strainer, hold it towards the window or some strong light. you should be able to look through every hole. Well done.
Insérez ici votre traduction
