Aller au contenu principal
Enlever l'antenne du Motorola V60i
Anglais
Français
Traduction de l’étape 1
Étape 1
Motorola V60i Antenna Replacement: étape 0, image 1 de 3 Motorola V60i Antenna Replacement: étape 0, image 2 de 3 Motorola V60i Antenna Replacement: étape 0, image 3 de 3
  • The antenna is located on top right corner of the phone while the front of the phone is facing you.
  • Unscrew the antenna clockwise until it is loose enough to remove from the phone.
L'antenne est située sur le dessus du téléphone.
Dévissez l'antenne jusqu'à ce qu'elle soit suffisamment libre pour pouvoir être retirée du téléphone.
-[* black] Antenna is located on top of phone.
-[* black] Unscrew antenna until loose enough to remove from phone.
+[* black] The antenna is located on top right corner of the phone while the front of the phone is facing you.
+[* black] Unscrew the antenna clockwise until it is loose enough to remove from the phone.
