Aller au contenu principal
Anglais
Français
Traduction de l’étape 3
Étape 3
The cable you're about to remove is very fragile - do not pull directly on the wires. Instead, try to pry up the connector directly, using your fingernails or a small flathead screwdriver if necessary.
  • The cable you're about to remove is very fragile - do not pull directly on the wires. Instead, try to pry up the connector directly, using your fingernails or a small flathead screwdriver if necessary.
  • Disconnect the fan connector from the interface board.
Insérez ici votre traduction
