Aller au contenu principal
Anglais
Français
Traduction de l’étape 1
Étape 1
Use the Pentalobe screwdriver to remove the two 3.8 mm Pentalobe screws near the dock connector.
  • Use the Pentalobe screwdriver to remove the two 3.8 mm Pentalobe screws near the dock connector.
A l'aide du tournevis Pentalobe, retirez les deux vis Pentalobe de 3,8 mm près du connecteur de dock.
Evitez d'utiliser le tournevis Pentalobe 5 points trop souvent car il risque d'endommager les vis.
[* red] Use the Pentalobe screwdriver to remove the two 3.8 mm Pentalobe screws near the dock connector.
-[* icon_caution] The 5-Point Pentalobe screwdriver should only be used a limited number of times because it has the potential to strip the screws.
