Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 2 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 1
Étape 1
Carefully wedge the tip of a spudger underneath the antenna cable connector. Delicately lift the spudger directly upwards to disconnect the antenna connector off its socket on the motherboard.
  • Carefully wedge the tip of a spudger underneath the antenna cable connector.
  • Delicately lift the spudger directly upwards to disconnect the antenna connector off its socket on the motherboard.
  • Some models have two antenna cables (blue and grey/white). Remove both of the cables.
Passez soigneusement la pointe d'une spatule (spudger) sous le connecteur du câble d'antenne.
Délicatement, soulevez la spatule pour déconnecter le connecteur d'antenne de sa prise sur la carte mère.
[* black] Carefully wedge the tip of a spudger underneath the antenna cable connector.
[* black] Delicately lift the spudger directly upwards to disconnect the antenna connector off its socket on the motherboard.
[* icon_note] Some models have two antenna cables (blue and grey/white). Remove both of the cables.
