Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront le tutoriel qui comprend ces étapes.
Anglais
Français
Traduction de l’étape 5
Étape 5
Tilt the display backwards. Grip the display from its base to reduce torque. Use a spudger to pry the upper part of the back panel by pushing in the tabs located along its length. This step is particularly tricky during reassembly, as the plastic must be perfectly aligned or it will not snap in. If it does not snap in correctly, the screen won't fit properly.
  • Tilt the display backwards. Grip the display from its base to reduce torque.
  • Use a spudger to pry the upper part of the back panel by pushing in the tabs located along its length.
  • This step is particularly tricky during reassembly, as the plastic must be perfectly aligned or it will not snap in. If it does not snap in correctly, the screen won't fit properly.
  • Carefully lift the display free of the case.
Insérez ici votre traduction
