Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Anglais
Français
Traduction de l’étape 6
Étape 6
Before you can seperate the motherboard from the front cover, you must disconnect the wire connecting the two. To do so, you must use the back end of the spudger to push out the two white tabs connected to the wire, that holds the motherboard and front cover together.
  • Before you can seperate the motherboard from the front cover, you must disconnect the wire connecting the two.
  • To do so, you must use the back end of the spudger to push out the two white tabs connected to the wire, that holds the motherboard and front cover together.
Insérez ici votre traduction
