Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Anglais
Français
Traduction de l’étape 3
Étape 3
The display panel is what shows all of your device's visuals. Although there are a wide variety of display panel types and sizes (LCD, LED, OLED, AMOLED), they're typically the most prominent feature of the device, which makes them very easy to identify. Look for a ribbon cable that connects the panel to the rest of the device. A growing number of modern devices, such as the iPhone, are combining the digitizer and the display panel into a single display assembly. This means that if either component fails, you need to replace the entire assembly.
Display Panel
  • The display panel is what shows all of your device's visuals.
  • Although there are a wide variety of display panel types and sizes (LCD, LED, OLED, AMOLED), they're typically the most prominent feature of the device, which makes them very easy to identify. Look for a ribbon cable that connects the panel to the rest of the device.
  • A growing number of modern devices, such as the iPhone, are combining the digitizer and the display panel into a single display assembly. This means that if either component fails, you need to replace the entire assembly.
Le panneau d'écran est le composant qui affiche le contenu visuel.
Bien qu'il existe une grande variété de types et de tailles de panneaux d'écran (LCD, LED, OLED, AMOLED), il s'agit habituellement de la caractéristique phare de l'appareil et il est donc facile à identifier. Cherchez simplement la nappe qui connecte l'écran au reste de l'appareil.
Sur un nombre croissant d'appareils, comme les iPhone, la vitre tactile et le panneau d'écran sont fusionnés en un seul module d'écran. Cela signifie qu'en cas de défaillance de l'un ou de l'autre, vous devrez remplacer tout le module.
