Aller au contenu principal
Fix Your Stuff
Right to Repair
Parts & Tools
Anglais
Français
Traduction de l’étape 18
Étape 18
The lens assembly of a camera houses the shutter and lens which allows your camera to take photos. The lens assembly is generally one of the largest components of a camera, and can be identified by a large ring that surrounds the shutter. On most cameras, the lens assembly is one of the last components that can be removed. Be patient when removing it, because it is fragile.
Lens Assembly
  • The lens assembly of a camera houses the shutter and lens which allows your camera to take photos.
  • The lens assembly is generally one of the largest components of a camera, and can be identified by a large ring that surrounds the shutter.
  • On most cameras, the lens assembly is one of the last components that can be removed. Be patient when removing it, because it is fragile.
Le bloc optique d'une caméra abrite l'obturateur et les lentilles qui permettent à votre caméra ou appareil photo de prendre des photos.
Le bloc optique est d'habitude l'un des plus grands composants d'une caméra et se reconnaît au grand anneau qui entoure l'obturateur.
Dans la plupart des caméras, il s'agit d'un des derniers composants à être enlevés. Soyez patient quand vous vous y mettez, car il est fragile.
