Aller au contenu principal
Anglais
Français
Traduction de l’étape 19
Étape 19
The flash assembly of a camera provides a quick burst of light when taking a photo that can brighten up otherwise dark environments. To identify the flash assembly, look for a small board that attaches to the rectangular light on the front of the device. When handling the flash assembly, make sure you have removed the battery from the camera. Most flash assemblies have capacitors, which can shock you if you touch the leads. It's also a good idea to make sure the capacitor has been discharged before handling it.
Flash Assembly
  • The flash assembly of a camera provides a quick burst of light when taking a photo that can brighten up otherwise dark environments.
  • To identify the flash assembly, look for a small board that attaches to the rectangular light on the front of the device.
  • When handling the flash assembly, make sure you have removed the battery from the camera. Most flash assemblies have capacitors, which can shock you if you touch the leads. It's also a good idea to make sure the capacitor has been discharged before handling it.
Le module flash d'une caméra fournit un bref éclair de lumière au moment de la prise d'une photo et permet ainsi d'éclairer les environnements sombres.
Pour trouver le module flash, repérez le petit circuit attaché à l'ampoule rectangulaire à l'avant de l'appareil.
Quand vous manipulez le module flash, vérifiez que vous avez retiré la batterie de la caméra. Beaucoup de flashs contiennent des condensateurs, vous pourriez vous électriser en touchant les pattes. Il est également de bon conseil de s'assurer qu'un condensateur a été déchargé avant de le toucher.
