Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Anglais
Français
Traduction de l’étape 2
Étape 2
Digitizers allow your device to recognize when and where you touch the screen. Digitizers themselves do not produce your device's visuals—that's the job of the display panel. They can usually be identified by a large glass panel, and a digitizer ribbon cable that connects it to the rest of the device. A growing number of modern devices, such as the iPhone, are combining the digitizer and the display panel into a single display assembly. This means that if either component fails, you need to replace the entire assembly.
Digitizer
  • Digitizers allow your device to recognize when and where you touch the screen. Digitizers themselves do not produce your device's visuals—that's the job of the display panel.
  • They can usually be identified by a large glass panel, and a digitizer ribbon cable that connects it to the rest of the device.
  • A growing number of modern devices, such as the iPhone, are combining the digitizer and the display panel into a single display assembly. This means that if either component fails, you need to replace the entire assembly.
Les vitres tactiles permettent à votre appareil de reconnaître quand et où vous touchez l'écran. Les vitres tactiles ne produisent pas les images de votre appareil – c'est le boulot du panneau d'écran.
Elles se reconnaissent habituellement à la grande vitre ainsi qu'à la nappe qui les relie au reste de l'appareil.
Un nombre croissant d'appareils modernes, comme l'iPhone, fusionnent la vitre tactile et le panneau d'écran en un seul module. Cela signifie qu'en cas de défaillance de l'un ou de l'autre, vous devrez remplacer le tout.
