Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Info : Vous modifiez actuellement un prérequis du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 6 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 16
Étape 16
Remove the battery. Before installing your new battery, remove all the old adhesive from the MacBook Pro's case.
  • Remove the battery.
  • Before installing your new battery, remove all the old adhesive from the MacBook Pro's case.
  • With a little luck, you can slowly pull out each strip of adhesive with your fingers.
  • Otherwise, soak each section of adhesive with a bit of adhesive remover for 2-3 minutes, and then scrape it out with an opening pick or one of the other tools in your kit. This can take quite a bit of work, so be patient.
  • Mop up any remaining adhesive remover and give your MacBook Pro a few minutes to air dry.
  • The replacement battery included in your iFixit kit comes with adhesive pre-installed. Test the battery's fit and alignment carefully before peeling off the film covering the adhesive, and then press each cell firmly into place. If any additional films/liners are present that weren't on your original battery, remove them now.
  • Calibrate your newly installed battery: charge it to 100%, and keep charging it for at least 2 more hours. Unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
  • If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook Pro's SMC.
Retirez la batterie.
Avant d'installer votre nouvelle batterie, ôtez tous les résidus de colle du boîtier du MacBook Pro.
Avec un peu de chance, vous arriverez à enlever toutes les bandes d'adhésif avec vos doigts.
Sinon, imprégnez-les d'un peu de dissolvant, attendez 2 à 3 minutes et raclez-les à l'aide d'un outil d'ouverture en plastique ou un des autres outils de votre kit. Il s'agit d'un travail un peu pénible qui nécessite de la patience.
Épongez tous les résidus de dissolvant et laissez votre MacBook Pro sécher à l'air pendant quelques minutes.
La batterie de rechange incluse dans votre kit iFixit est déjà munie de bandes adhésives. Vérifiez bien l'emplacement de la batterie, puis enlevez le film recouvrant l'adhésif et mettez chaque cellule à sa place en enfonçant bien. En cas de films/doublures supplémentaires, absents sur votre batterie d'origine, retirez-les maintenant.
Calibrez votre nouvelle batterie avant de l'utiliser : Chargez-la à 100%, puis laissez-la charger encore au moins deux heures. Utilisez votre appareil normalement jusqu'à ce qu'il s'éteint à cause d'une batterie vide. N'oubliez pas de sauvegarder votre travail à temps. Attendez au moins 5 heures, puis rechargez la batterie à 100% sans interruption.
Si vous remarquez quelque chose d'inhabituel ou des problèmes après avoir installé votre nouvelle batterie, réinitialisez le contrôleur de gestion du système (SMC) de votre Mac.
