Aller au contenu principal
Anglais
Français
Traduction de l’étape 2
Étape 2
Remove the plastic cover from the back. Pry it off from the top first with a thin plastic shim, then remove it from the two bottom clips. When removing the top part do not bend it too far down, or else you risk breaking the two bottom clips. When removing the top part do not bend it too far down, or else you risk breaking the two bottom clips.
  • Remove the plastic cover from the back. Pry it off from the top first with a thin plastic shim, then remove it from the two bottom clips.
  • When removing the top part do not bend it too far down, or else you risk breaking the two bottom clips.
Insérez ici votre traduction
