Aller au contenu principal
Anglais
Français
Traduction de l’étape 8
Étape 8
Alternatively, you can put your waders in the dryer. Place your waders in the dryer. Set the dryer to a normal dry-cycle time on low heat.
  • Alternatively, you can put your waders in the dryer.
  • Place your waders in the dryer.
  • Set the dryer to a normal dry-cycle time on low heat.
  • Start the dryer.
  • You may have to run the dryer for several cycles to get your waders completely dry. Be patient, making sure you rearrange your waders inside the dryer for best results. Make sure they are dry inside and out to prevent the appearance of mold or mildew.
Vous pouvez également sécher votre wader à la machine.
Mettez le wader au sèche-linge.
Choisissez un cycle normal, à température modérée.
Mettez le sèche-linge en route.
Vous devrez peut-être faire plusieurs cycles pour faire complètement sécher votre wader. Ne négligez pas cette étape, vous éviterez que votre wader ne moisisse.
[* black] Alternatively, you can put your waders in the dryer.
[* black] Place your waders in the dryer.
[* black] Set the dryer to a normal dry-cycle time on low heat.
[* black] Start the dryer.
-[* icon_note] You may have to run the dryer for several cycles to get your waders completely dry. Be patient, making sure your waders are fully dry ensures they won't grow mold or mildew.
+[* icon_note] You may have to run the dryer for several cycles to get your waders completely dry. Be patient, making sure you rearrange your waders inside the dryer for best results. Make sure they are dry inside and out to prevent the appearance of mold or mildew.
