Aller au contenu principal
Info : Vous modifiez actuellement un pré-requis du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 2 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 29
Étape 29
Insert the tip of a spudger under the connector end of the microphone ribbon cable and lift to peel that section up from the upper case. Insert the tip of a spudger under the connector end of the microphone ribbon cable and lift to peel that section up from the upper case. Insert the tip of a spudger under the connector end of the microphone ribbon cable and lift to peel that section up from the upper case.
  • Insert the tip of a spudger under the connector end of the microphone ribbon cable and lift to peel that section up from the upper case.
Insérez ici votre traduction
