Aller au contenu principal
Anglais
Français
Traduction de l’étape 1
Étape 1
  • METHOD 1: Use a plastic pry tool to pop the back of the tablet off. Be careful the aluminum back is attached via plastic hooks.
  • METHOD 2: Access by removing the screen (suggested by Quantum Byte)
  • If like me you are unable to find a gap to detach the aluminium back from the frame so instead I tried accessing by removing the screen using a sharp tool (a metal blade such as a Stanley knife or a flat-ended spudger) as in the video (not my work).
  • Unfortunately, this is not as easy as in the video as the entire outer edge seems to be glued. Furthermore, the screen cracks v. easily. Since my screen was already damaged, I ended up breaking up and tearing the screen off. I am perhaps not best to advise on this method.
  • I suggest using a hair dryer/ heat gun to melt the glue sufficiently to make the screen detach.
Insérez ici votre traduction
