Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront le tutoriel qui comprend ces étapes.
Anglais
Français
Traduction de l’étape 16
Étape 16
Insert a spudger under the GPS connector end of the upper component board and lift it up off of its adhesive. Be very careful not to scrape the board against the top of the rear case.
  • Insert a spudger under the GPS connector end of the upper component board and lift it up off of its adhesive.
  • Be very careful not to scrape the board against the top of the rear case.
  • The GPS antenna cable will slide out of its ZIF socket when you do this. On reassembly, fit the cable back into the socket as you replace the upper component board.
Insérez ici votre traduction
