Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront le tutoriel qui comprend ces étapes.
Anglais
Français
Traduction de l’étape 19
Étape 19
To remove the upper component board you will be pulling gently on its cable while lifting it up enough to clear the battery, but not high enough to scrape against the rear case. Go slowly and carefully. Insert the tip of a spudger under the upper component board to lift it slightly. Pull the board up and out of the space between the battery and the rear case bezel.
  • To remove the upper component board you will be pulling gently on its cable while lifting it up enough to clear the battery, but not high enough to scrape against the rear case. Go slowly and carefully.
  • Insert the tip of a spudger under the upper component board to lift it slightly.
  • Pull the board up and out of the space between the battery and the rear case bezel.
  • Remove the upper component board.
  • On reassembly, you'll want to reconnect the GPS antenna cable at this point. Use tweezers and work carefully.
Insérez ici votre traduction
