Aller au contenu principal
Anglais
Français
Traduction de l’étape 5
Étape 5
Push the AirPort/Bluetooth card slightly downwards, 1-2 mm at most. With a firm grip on the edges of the AirPort/Bluetooth card, pull it straight out of its socket on the underside of the logic board. Do not use excessive force to pull the end of the AirPort/Bluetooth card away from its socket on the logic board.  Doing so may cause severe damage.
  • Push the AirPort/Bluetooth card slightly downwards, 1-2 mm at most.
  • With a firm grip on the edges of the AirPort/Bluetooth card, pull it straight out of its socket on the underside of the logic board.
  • Do not use excessive force to pull the end of the AirPort/Bluetooth card away from its socket on the logic board. Doing so may cause severe damage.
  • Try not to touch the antenna connector sockets with your fingers, as the oils can corrode the metal and prevent good contact.
Insérez ici votre traduction
