Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Anglais
Français
Traduction de l’étape 16
Étape 16
Insert a spudger under the end of the upper component board and gently slide it toward the volume rocker to free the board from adhesive. Be very careful not to bend the board too much or scrape it against the top of the rear case. Be very careful not to bend the board too much or scrape it against the top of the rear case.
  • Insert a spudger under the end of the upper component board and gently slide it toward the volume rocker to free the board from adhesive.
  • Be very careful not to bend the board too much or scrape it against the top of the rear case.
Insérez un spudger sous l'extrémité de la carte des composants supérieurs et faites-le délicatement glisser vers le bouton de volume pour décoller la carte de l'adhésif.
Faites très attention à ne pas trop plier la carte ni l'érafler contre le haut de la coque arrière.
