Aller au contenu principal
Disassembling Canon PowerShot SX200 IS
Anglais
Français
Traduction de l’étape 14
Étape 14
Disassembling Canon PowerShot SX200 IS: étape 0, image 1 de 3 Disassembling Canon PowerShot SX200 IS: étape 0, image 2 de 3 Disassembling Canon PowerShot SX200 IS: étape 0, image 3 de 3
  • On the bottom left hand side of the lens assembly there is a connector with a red and a black wire going to the speaker. Disconnect this, taking great care not to strain the wires or especially the ribbon that the socket is mounted on.
  • At the rear top left hand side of the lens assembly is a ribbon cable connecting it to the flash module. Disconnect this.
  • (Note the transparent protective insulation covering the flash board just below this connector. Do not remove this as the board may still have a dangerous high voltage on it from the flash capacitor behind.)
  • Remove a screw from the top right hand side of the flash module, and separate the flash module from the lens assembly.
  • (On reassembly, hold the flash head closed while refitting it to the lens assembly.)
Insérez ici votre traduction
