Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 6 tutoriels qui comprennent cette étape.
Traduction de l’étape 5
Étape 5
Rotate the camcorder so that the tape compartment is facing you.
Remove the single 4.5mm black screw above the hook for the hand strap.
Rotate the camcorder so that the lens is facing you.
Remove the single 4.5mm black screw from the front panel.
[* black] Rotate the camcorder so that the tape compartment is facing you. | |
[* black] Remove the single 4.5mm black screw above the hook for the hand strap. | |
+ | [* icon_note] Undoing the strap on one end may help. |
[* black] Rotate the camcorder so that the lens is facing you. | |
[* black] Remove the single 4.5mm black screw from the front panel. |
