Aller au contenu principal
Anglais
Français
Traduction de l’étape 4
Étape 4
Remove the following four screws securing the hard drive and IR sensor cable to the upper case: Two 1.5 mm Phillips screws. Two 4 mm Phillips screws.
  • Remove the following four screws securing the hard drive and IR sensor cable to the upper case:
  • Two 1.5 mm Phillips screws.
  • Two 4 mm Phillips screws.
  • Slide the hard drive and IR sensor bracket away from the edge of the upper case.
  • Carefully peel the hard drive and IR sensor cable from the upper case.
  • Remove the hard drive/IR sensor cable from the upper case and set it aside.
Insérez ici votre traduction
