Aller au contenu principal
Remplacement de la RAM du Dell Optiplex 745 USFF
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront le tutoriel qui comprend cette étape.
Anglais
Français
Traduction de l’étape 1
Étape 1
Dell Optiplex 745 Ultra Small Form Factor RAM Replacement: étape 0, image 1 de 1
  • Press down on the two white tabs on either side of the memory module; the RAM will pop out.
  • Be sure you are grounded to avoid electrostatic discharge, and place your memory modules in an anti-static bag.
  • Make sure the notch in the RAM lines up with the notch in the slot. It should enter the slot with minimal force. If it does not enter the slot, check that you have the RAM lined up properly.
Appuyez sur les deux onglets blancs de chaque côté du module de mémoire. la RAM va sortir.
Assurez-vous d'être à la terre pour éviter les décharges électrostatiques et de placer vos modules de mémoire dans un sac antistatique.
[* black] Press down on the two white tabs on either side of the memory module; the RAM will pop out.
-[* icon_reminder] Be sure you are grounded to avoid electrostatic discharge and to place your memory modules in an anti-static bag.
+[* icon_caution] Be sure you are grounded to avoid electrostatic discharge, and place your memory modules in an anti-static bag.
+[* icon_reminder] Make sure the notch in the RAM lines up with the notch in the slot. It should enter the slot with minimal force. If it does not enter the slot, check that you have the RAM lined up properly.
