Aller au contenu principal
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 18 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 1
Étape 1
The next two steps demonstrate using the iSclack, a great tool for safely opening the iPhone 6 Plus that we recommend for anyone doing more than one repair. If you aren't using the iSclack, skip down two steps. If the plastic depth gauge is attached at the center of the iSclack, remove it now—it's not needed for larger phones like the iPhone 6 Plus. Close the handle on the iSclack, opening the suction cup jaws.
  • The next two steps demonstrate using the iSclack, a great tool for safely opening the iPhone 6 Plus that we recommend for anyone doing more than one repair. If you aren't using the iSclack, skip down two steps.
  • If the plastic depth gauge is attached at the center of the iSclack, remove it now—it's not needed for larger phones like the iPhone 6 Plus.
  • Close the handle on the iSclack, opening the suction cup jaws.
  • Place the bottom of your iPhone in between the suction cups.
  • Position the iSclack's upper suction cup against the display, near the home button.
  • Open the handles to close the jaws of the iSclack. Center the suction cups and press them firmly onto the top and bottom of the iPhone.
  • If your display or back glass is badly cracked, covering it with a layer of clear packing tape may help the suction cups adhere. The iSclack also includes two pieces of tape for this purpose.
Les deux prochaines étapes vous montrent comment utiliser l'iSclack, une pince spécialement conçue pour ouvrir votre iPhone 6 Plus en toute sécurité, et que nous recommandons à tous ceux qui effectuent souvent de réparations. Si vous n'utilisez pas d'iSclack, autez deux étapes.
Si la jauge de profondeur en plastique est attachée au milieu de l'iSclack, retirez-la, elle n'est pas nécessaire pour les iPhone de grande taille tel que l'iPhone 6 Plus.
Serrez les poignées pour ouvrir les mâchoires avec les ventouses.
Placez la partie inférieure de votre iPhone entre les deux ventouses.
Positionnez la ventouse supérieure contre la vitre près du bouton home.
Ouvrez les poignées pour fermer les ventouses. Centrez et exercez une pression sur les ventouses.
Si votre écran ou coque arrière est brisé, le recouvrir avec une couche de ruban adhésif transparent peut aider les ventouses à adhérer. L'iSlack comprend également deux morceaux de ruban adhésif à cet effet.
