Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 5 tutoriels qui comprennent cette étape.
Traduction de l’étape 4
Étape 4
Peel back the final battery adhesive tab from the bottom edge of the battery. Gently pull the battery adhesive tab upward and away from the battery, allowing the adhesive strip to slowly slide out from between the battery and the rear case.
Continue pulling until the final strip comes free from the iPhone.
Wait about one minute for the alcohol solution to weaken the adhesive. Use the flat end of a spudger to gently lift the battery.
[* black] Peel back the final battery adhesive tab from the bottom edge of the battery. [* black] |
[* icon_caution] Place one hand over the battery as the final strip comes out, or it may fling the battery out of the iPhone. |
[* black] Continue pulling until the final strip comes free from the iPhone. |
[* icon_caution] If any of [* black] Wait about one minute for the alcohol solution to weaken the adhesive. Use the flat end of a spudger to gently lift the battery. [* icon_caution] Don't try to forcefully lever the battery out. If needed, apply a few more drops of alcohol to further weaken the adhesive. Never deform or puncture the battery with your pry tool. [* icon_caution] '''Do not''' pry against the logic board, or you may permanently damage your iPhone. '''Do not''' pry under the topmost section of the battery, near the volume up button and mute switch, or you may damage the [guide|31183|audio controls cable|stepid=74381|new_window=true], which is adhered to the rear case just beneath the battery. [* icon_note] For alternative methods to unstick the battery, '''continue with the next step below'''. |
