Anglais
Français
Traduction de l’étape 1
Étape 1
With the front display of the device facing you, rotate the device 90 degrees counter clockwise. Now rotate the device 180 degrees and remove the second screw. Remove the screw that is on the right side of the panel facing you.
  • With the front display of the device facing you, rotate the device 90 degrees counter clockwise.
  • Now rotate the device 180 degrees and remove the second screw.
  • Remove the screw that is on the right side of the panel facing you.
  • All screws will need to be removed with a phillips head screwdriver.
Insérez ici votre traduction
