Aller au contenu principal
Anglais
Français
Remplacement du panneau avant de l'iPhone 6 Plus
Informations sur le tutoriel
= Terminé = Incomplet
Front Panel
LCD and Digitizer
iPhone 6 Plus Front PanelLCD and Digitizer Replacement
Replace the Front PanelLCD and digitizer (A.K.A. front panel) in your iPhone 6 Plus.
    Use this guide to strip and replace your cracked or broken iPhone 6 Plus screen. It will show you how to remove the home button, front-facing camera and sensor assembly, LCD shield plate, and home button ribbon cable—all of which will need to be transferred to your replacement panel. To replace the entire assembly instead, follow [https://www.ifixit.com/Guide/iPhone+6+Plus+Display+Assembly+Replacement/30265|this much shorter guide].
    For an easier repair, use our [product|IF269-000|fix kit|new_window=true] and follow [guide|30265|this shorter guide] to replace your iPhone’s entire screen.
    In either caseFor more advanced fixers, this guide will help you replace ''only'' the iPhone’s LCD and digitizer assembly (a.k.a. the bare “front panel”). This requires you to transfer several components from your original screen to the new one before installing it—including the front-facing camera, earpiece speaker, LCD shield plate, and home button assembly.
    For all screen/display repairs
    , it's important to transfer the original home button onto the new display in order for Touch ID (fingerprint scanning) to function.
    [video|https://www.youtube.com/watch?v=-uGY9cmERZY]
      Décrivez la pièce ou le composant spécifique de ce device sur lequel vous êtes en train de travailler. Par ex : batterie
      Créer un titre.
      Ce bref résumé n'apparaîtra que dans les résultats de recherche.
      Communiquez des informations de base avant que le lecteur ne se plonge dans le tutoriel.
      Étapes du tutoriel
      Étape 1
      Enlevez les deux vis Phillips de 1,7 mm (une en haut et une en bas), qui attachent la plaque de protection LCD à l'écran.
      Étape 2
      Dévissez les trois vis Phillips de 1,3 mm de chaque côté de la plaque de protection de l'écran LCD (six au total)
      Étape 3
      Lors de la prochaine étape, il faut décoller un côté de la nappe de bouton home (en rouge sur la deuxième photo) qui est attachée au dos de l'écran par un adhésif fort. Nous recommandons fortement l'utilisation d'un iOpener pour chauffer la partie inférieure de l'écran, directement sur le bouton home.
      Étape 4
      Soulever soigneusement la plaque de protection de l'écran LCD sans l'enlever en écartant le côté le plus près du haut-parleur interne de quelques millimètres de l'écran.
