Aller au contenu principal
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 3 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 1
Étape 1
Pry the charge port connector cable up from its socket on the logic board with the flat end of a spudger. Pry the charge port connector cable up from its socket on the logic board with the flat end of a spudger.
Disconnect Charge Port
  • Pry the charge port connector cable up from its socket on the logic board with the flat end of a spudger.
A l'aide de l'extrémité plate d'une spatule (spudger), faites levier sur le connecteur de la nappe du vibreur pour l'enlever de sa prise sur la carte mère.
-[* black] Pry the vibrator connector cable up from its socket on the logic board with the flat end of a spudger.
+[title] Disconnect Charge Port
+[* black] Pry the charge port connector cable up from its socket on the logic board with the flat end of a spudger.
