Aller au contenu principal
Info : Vous modifiez actuellement un pré-requis du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 7 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 1
Étape 1
Insert the flat end of a spudger between the thin rubber strip surrounding the front display bezel and the rear display bezel. Do not try to insert the spudger between the thin rubber strip and the plastic face of the front display bezel. Use the flat end of your spudger to carefully pry the front display bezel away from the adhesive securing it to the rear display bezel.
  • Insert the flat end of a spudger between the thin rubber strip surrounding the front display bezel and the rear display bezel.
  • Do not try to insert the spudger between the thin rubber strip and the plastic face of the front display bezel.
  • Use the flat end of your spudger to carefully pry the front display bezel away from the adhesive securing it to the rear display bezel.
  • Do not pry against the fragile glass LCD panel. Also, do not excessively bend the plastic as it may permanently deform.
  • Continue prying until the front display bezel is free along the right side of the display and behind the right clutch hinge.
Insérez ici votre traduction
