Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Anglais
Français
Traduction de l’étape 2
Étape 2
To remove the logic board from the body, use the #00 phillips head screwdriver and remove the 4mm silver screw from right side of the board. Next, rotate the camcorder so the front is facing you and remove the 4mm silver screw from the front panel. Carefully lift the logic board away from the camcorder.
  • To remove the logic board from the body, use the #00 phillips head screwdriver and remove the 4mm silver screw from right side of the board.
  • Next, rotate the camcorder so the front is facing you and remove the 4mm silver screw from the front panel.
  • Carefully lift the logic board away from the camcorder.
Insérez ici votre traduction
