Aller au contenu principal
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront le tutoriel qui comprend ces étapes.
Anglais
Français
Traduction de l’étape 2
Étape 2
Place the plastic opening tool under the logic board. Using one hand to stabilize the device, use the tool to lift the logic board away from the plastic case. If the board doesn't come up easily, try not to force it as the board may break. Instead, apply even pressure to lift it away gently from the casing. You will need to gently lift at 2-3 locations around the board. During reassembly, gently push on 2-4 locations with your fingers until the board clicks into place.
Remove the logic board
  • Place the plastic opening tool under the logic board.
  • Using one hand to stabilize the device, use the tool to lift the logic board away from the plastic case. If the board doesn't come up easily, try not to force it as the board may break. Instead, apply even pressure to lift it away gently from the casing. You will need to gently lift at 2-3 locations around the board.
  • During reassembly, gently push on 2-4 locations with your fingers until the board clicks into place.
Placez l'outil d'ouverture en plastique sous la carte logique.
En utilisant une main pour stabiliser l'appareil, utilisez l'outil pour soulever la carte logique du boîtier en plastique. Si le tableau ne se présente pas facilement, essayez de ne pas le forcer car la carte pourrait se casser. Au lieu de cela, appliquez une pression uniforme pour le soulever doucement du boîtier.
Pendant le remontage, poussez doucement sur 2-4 emplacements avec vos doigts jusqu'à ce que la carte s'enclenche.
