Aller au contenu principal
MacBook Unibody Model A1342 Front Display Bezel Replacement
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 7 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 1
Étape 1
MacBook Unibody Model A1342 Front Display Bezel Replacement: étape 0, image 1 de 3 MacBook Unibody Model A1342 Front Display Bezel Replacement: étape 0, image 2 de 3 MacBook Unibody Model A1342 Front Display Bezel Replacement: étape 0, image 3 de 3
  • Insert the flat end of a spudger between the thin rubber strip surrounding the front display bezel and the rear display bezel.
  • Do not try to insert the spudger between the thin rubber strip and the plastic face of the front display bezel.
  • Use the flat end of your spudger to carefully pry the front display bezel away from the adhesive securing it to the rear display bezel.
  • Do not pry against the fragile glass LCD panel. Also, do not excessively bend the plastic as it may permanently deform.
  • Continue prying until the front display bezel is free along the right side of the display and behind the right clutch hinge.
Insérez ici votre traduction
