Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Anglais
Français
Traduction de l’étape 7
Étape 7
Failure to utilize the specified tool in the proper way may cause damage to the device. Pry up the black connector using a pick. This should lock the black connector into an upward position, which will release the copper ribbon connected to the phone's camera.
  • Failure to utilize the specified tool in the proper way may cause damage to the device.
  • Pry up the black connector using a pick. This should lock the black connector into an upward position, which will release the copper ribbon connected to the phone's camera.
Le non suivi de l'utilisation correcte de l'outil spécifié peut causer des dommages à l'appareil
Utilisez la sélection pour soulever le connecteur noir.
Le connecteur noir doit se verrouiller en place en restant dans une position ascendante.
Le ruban connecté à l'appareil photo du téléphone sera libéré.
[title] Flip Black Connetor
* icon_caution] Failure to Utilizeutilize the Specified Toolspecified tool in the Proper Way May Cause Damageproper way may cause damage to the Devicedevice.
[* black] Use pick to pryred] Pry up the black connector.
[* black] The
black connector using a pick. This should lock the black connector into place remaining in an upward position.
[* black] The
position, which will release the copper ribbon connected to the phone's camera will be releasedcamera.
[* black] The
[* black] The
